i7-4770k build not booting need help?
imconfsdru
19
Computer not booting... Doesnt even get to post screen and just shuts off completely??
After it shuts off.have to either reset cmos jumper, and or unplug power then plug back in or it wont do anything. The PC was fine then went to turn it on and when I pressed power you can see the cpu cooling fan start to spin up then it.just turns off.instantly doesnt even make.it.to pre post bios screen?
So replaced the power suply, and then the motherboard, double checked the ram was good, so only thing left is the Cpu right?
Here is my build specifications:
ASROCK Z97 FATALITY Motherboard
i7-4770k Cpu
2-8gb sticks of Corsair ddr3 2400 ram
Corsair CX850 power supply
Corsair CM300 M.2 SSD
Crucial MX500 SSD
Western Digital 2tb Cavier Harddrive
Win 10pro newest build version dont remember build version off top of my head sry.
