i7 4770K cpu input voltage question
SamDe
57
Hello
Today I noticed in my BIOS that my cpu has an input voltage of around +1.744 V.
To be honest I have no idea if this is bad or good but is seems a bit high to me. I'm not Overclocking.
Specs:
ASRock Z87 Extreme 4
I7-4770K @3.50 stock (3.90 turbo) (no OC)
Sapphire HD6870 (currently on Intel HD integradted graphics due to GPU errors atm)
Kingston HyperX 8GB (2 x 4GB) DDR3-1866 (KHX18C9T2K2/8X)
Kingston SSD 120G
2x extra HD's
Thanks!
That is about average. That is the voltage supplied by the Motherboard to the CPU essentially. The CPU's VRMs then regulates it again to run the CPU itself.
So the core voltage will be up to 1.2 on a stock processor with a Vin of somewhere around 1.7. The system can handle about a max of 1.9v on air cooling with a Vcore of 1.3. If you bump up to water cooling you can get away with a little more.
Thanks! So nothing to worry about? 😀
If i went into OC, what lines should be the ones I should be worrying about/ keeping an eye on?
Ok thanks for the answers! +1
