Question I7 4770k cpu usage low fps
Jun 4, 2020
Hello im new I have an i7 4770k with 1080 16gb of ram and the CPU is at 4.2ghz it won't go any higher.
My question is my fps is low on call of duty warzone while streaming around average 70-70 and my you is %100 and gou around %92 is there anything I can do to improve the.i would like to get the benefit out of my 144hrz monitor.
Phaaze88
Splendid
Ambassador
I think I remember reading that NVENC is actually worse quality on GTX 1000 over the RTX 2000 and CPU encoding. Edit - I think I may be wrong on the details, but either way CPU encoding is better and OP should look at getting minimum a Ryzen 5 3600.
I was not aware of the 10 series being worse.
I suggested NVENC as a stopgap, simply because the OP doesn't have any headroom to stream with that cpu heavy game.
From what I have seen of the quality, I doubt it will be so terrible that it won't be worth using if used only for streaming if it's an option for streaming, but it's not really a great option for recording game-play for editing and releasing online.
