i7-4770k Really Unusual Overclocking Problem
Drummerdude1099
45
Firstly, my rig (in order of relevance to subject):
i7-4770k
Gigabyte z87x-ud4h
Cooler Master V8 (not the new one)
G. Skill Ripjaws X 2x4GB 1600 MHZ RAM
Rosewill Capstone 550w Modular PSU
GTX 770 Gigabyte Windforce Superclocked w/ 4GB Vram
Seagate 1tb SSHD
Ok so I did a lot of research into overclocking, because this is my first overclockable PC. At first, I tried just changing the multiplier to 42 and leaving the base clock at 100 to see if it was stable. I played hours of intense games (Far Cry 3, BF4, BF3, Skyrim, etc.) I then ran Prime 95 while monitoring temperatures. It did not find any errors and no blue screens, and temperatures did not go above 145-ish Fahrenheit. I looked at CPU-Z, and everything registered correctly. So then I turned my computer off for the night and went to bed. When I turned my computer on, before POSTing it turned off restarted and after POSTing gave me a message that there was an error starting, and that it loaded optimized defaults. I then could go into BIOS do what ever overclock I wanted and go back into Windows 7 Ultimate and never have a problem with my testing. I tried an overclock at 4.4 ghz, 3.9, 4.1, etc. All of them were stable, although the same problem kept presenting itself when I tried to turn off and then on. I even tried following Intel God's quick and dirty guide to Haswell over clocking. It did not change anything. Only other thing to mention would be that before I started attempting to OC, when I would shut down from Windows, the fans would remain on, but when I overclock and shut down they turn completely off.
Why are you overclocking that beast of a machine? Do you need to...? Is there anything under the sun that it doesn't handles today... why shorten the life of components needlessly... just because you built a machine that is capable of overclocking doesn't means you should start doing it right of the bat... do it when you need it.
Other wise as to answer your question, what i can see is your PSU is 550W only, your system should be cutting real close with that PSU. I have a far less powerful build and do not overclock and i have a 600W PSU myself, so please look if your PSU provides enough power to do overclocking with your system.
