I just bought an i7 4790 last week (without k on it) i really don't do overclock and i'm a freelance character game designer (8 threads will be totally fine with me!) and the only available product on i7 is 4790 + i have a R9 270 which i bought from a friend.
System:
CPU: Intel Core i7 4790
CPU Cooler: n/a
Motherboard: Asus H97M-E
Graphics: Sapphire Dual-X R9 270 2GB GDDR5
Memory: Kingston Hyper X HX318C10FK2/8 8GB (2x4GB) Blue
Solid State Drive: n/a
Hard Drive: 800GB (320GB Western Digital Blue + 500GB Seagate Barracuda)
Case: Xigmatek Shockwave
Power Supply: Raider 750W
Cable Kit: n/a
Additional Lightning: n/a
Fans: 120mm Front mounted Xigmatek CLF Blue LED Fan
Additional Fans: n/a
Operating System: Windows 7 Ultimate 64bit
The problem is even if i go on Ultra settings on Watchdogs my FPS drops for around 15 and going back to 25 or something like that (not accurate) it makes a choppy lag. But when i go on High its just fine (25-30fps). I just want to know whats the problem so next time i know what should i upgrade.
And when i'm using Fraps for recording it's really bad! The drop of FPS is the same as the High and Low settings, i figure out to record in low maybe it's just about the settings but the choppy lag is the same as High Settings.
Does the problem is my CPU? Should i overclock it? The driver's of my GPU is totally in Update
( http://support.amd.com/en-us/download/desktop?os=Windows%207%20-%2064 ) ***14.11 BETA**
Maybe it's on my fraps settings?
FPS tab:
Benchmark Settings:
FPS (check)
Frametimes
MinMaxAvg
Stop benchmark after 60 seconds (not check)
Moves Tab:
Video Capture Settings:
60
50
30
20 (check)
Full size (check)
Half Size
Loop Buffer length "30" seconds
System:
CPU Cooler: n/a
Cable Kit: n/a
FPS tab:
Benchmark Settings:
FPS (check)
Frametimes
MinMaxAvg
Moves Tab:
60
50
30
20 (check)
Full size (check)
Half Size
