i7-4790k better than i7-7700k ??
Own_1
Commendable
Jun 21, 2016
74
so i just upgraded from an i7-4790k to an i7-7700k
and from 1600mhz ram to 3000mhz ram , so i benchmarked my new cpu and here are the scores (btw this is my own benchmark in cs go)
on the i7-7700k = 950 avg , 217 minimum
on the i7 -4790k = 1500 avg , 650 minimum
how is this possible ?
even thought i tried other benchmarks and all of them tell me that the kaby lake chip is better but for some reason i get lower fps in cs go ???? help ?
I'm trying to take this seriously, so...did you have an OC on your 4790k? What's the 7700k running at? If you're not OC'ing, it may not be stressing the CPU enough for Turbo Boost to kick in. It could even be running in a power saving mode at a reduced frequency.
Good point actually I can't even hit 300fps on csgo with my i7 7700k, even low settings and really low res changes nothing, probably something I'm missing but oh well not bothered, don't need more frames than your monitor refresh rate anyway.
i told you , i did "real" benchmarks and the i7-7700k came up on top but for some reason the fps is lower ?
both oc'ed to 4.8
the i7-4790k scored 935 in cinebench
i7-7700k scored 1047 in cinebench
i play on 1024x768 lowest settings and i have 1070
iam kinda of in a way to semi pro road 😱
i did cinebench and the new cpu came up on top but for some reason the fps is less ?
both running win 10
both 16 gb ram the old one on 1600mhz and the new one 3000mhz
gtx 1070
fairly high temps for a 1.27 v but less than 85
i play on fps_max 0 so my fps in unlimited and in deathmatch my fps goes from 250-400
but in my own cs go benchmark why is fps lower than with the new cpu
Yeah maybe I am but it's unlikely cause I only hit around 280fps, also in the loading screen it once went to 2500
cinebench for example, puts a load on the cpu and see how fast and how well it did perfom
my laptop with a a8 gives 175 cb on that test
if you compare it with a older or with less cores cpu you will see a performance reduction and more time, also less cb points
this test is pretty simple, you can run other tests, like compress or decompress a 1 gb file with 7zip or something like that, usually newer cpus will finish faster than older cpus
the last 3 or 4 years of intel cpus hasn't changed much and numbers hasn't changed on those test much
the temperature mentioned can do the performace decrease while gaming, also problems with the gpu driver itself
