Hello, i bought a i7 4790k two weaks ago , this temprature ok for it? or should i worry about? i'm using with gelid tranquillo cpu cooler 1.16v @4.4ghz. Should i consider delid case? Thank u for helping.
for testing 25 minute aida64What is the temp? If there's a pic it's not showing up.
Those temps are fine for stress testing. Anything under 80C is safe.for testing 25 minute aida64
Core 1 Min 35c max 71c Avrg 62.3c
Core 2 Min 36c max 74c Avrg 64.8c
Core 3 Min 39c max 75c Avrg 65.7c
Core 4 Min 34c max 74c Avrg 61.3c
Thank you, should i consider delid option? or should i say "everthing just fine nevermind" ?Those temps are fine for stress testing. Anything under 80C is safe.
I wouldn't bother deliding it as its a big risk and not worth the slightly higher OC or slightly better temps.Thank you, should i consider delid option? or should i say "everthing just fine nevermind" ?
