i7-4790K MB help
cunningimpulse
So I am planning on upgrading my CPU and I want to upgrade it too the i7-4790K because I heard that it is a really good cpu. I am planning on upgrading my MB along with me CPU so, what is the best gaming MB for the i7-4790K?
That is an older platform: Try this: 8th Generation
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor ($279.89 @ B&H)
CPU Cooler: be quiet! - Pure Rock Slim 35.1 CFM CPU Cooler ($21.49 @ SuperBiiz)
Motherboard: Gigabyte - Z370 AORUS Ultra Gaming (rev. 1.0) ATX LGA1151 Motherboard ($119.99 @ Newegg)
Memory: Patriot - Viper Elite 8GB (2 x 4GB) DDR4-2400 Memory ($74.99 @ Newegg)
Total: $496.36
Generated by PCPartPicker 2017-11-10 21:42 EST-0500
Total: $496.36
What are your current system specs ? I think unless you are getting a new 4790k for ultra cheap there is no point in going with this cpu at this stage. The 4790k is a great cpu but is still on DDR3 and there are 3 new generations out now that are ahead of this. There are better I7 CPU out there for example 6700k 7700k these 2 are basically the same thing but would recommend the 6700k due to it having better thermals. The new 8700k is new 6 core with 12 threads cpu. Its more expensive than the previous I7 s . This all comes down to what you have to spend. There is a 8600k I5 which only has 6 threads/cores. If you want my opinion i would get the 8700k and you are safe to assume you PC is going to be a monster with that CPU. If you are short on cash than try to stick to a good budget set up 6700k is not a bad choice other will disagree with me.
