hi, i have overclocked my i7 4790k to 4.6ghz. i know its not much but i want to get the hang of it before i get to 4.7 or 4.8ghz. i finished up with 1.230 volts on the cpu voltage. i know this isnt alot but i also want to ensure that when the pc is being used for gaming or under load that the cpu can have less voltage flowing through it and in theory decreasing temperature at idle, increasing it longevity. so currently i have a minus offset of 0.100 volts but i am running at 1.300 volts on the actual vcore after i have changed the voltage from manual (when it was at 1.23) to adaptive.now in cpu-z, the cpu idles at 1.201 volts and when gaming jumps to around 1.231 volts. im just not sure if 1.201 volts at idle is low enough compared to what the voltage would get to with no overclock and everything on auto. i cant find online a good offset value guide to follow so im wondering if anyone can give my a guide/solid answer.
for reference i have:
mobo: asus sabertooth z97 mk2
cooler: cooler master hyper 212x (not amazing but i think it should do)
and if its of any importance for some reason i am running 2 gtx 980's in sli with a cs 850w power supply.
thanks in advance for any help i can get
