I have an I7 4790k and my case is slightly smaller so I have not found a watercooler to fit it yet. In the mean time im using the cooler master hyper 212 evo.
Lately I have been running a minecraft server and playing minecraft which means about 40% cpu load. For whatever reason my temps sit at the 70s, going to 80s sometimes. Ive had some heat problems in the past and I am desperate, i would be completely fine with "underclocking" my pc as the cpu is a bit overkill as it is paired with a gtx 970.
Im hesistant to remount the cooler as it was a bitch to mount in the first place but i may do it over summer break (~3 weeks) in the mean time what should I check, i cleaned my case yesterday and temps have dropped minimally.
Sorry for the long post, Just dont want to have to buy a new cpu...
