i7 4790k vs i5 4460 triple monitor
JcV125
I was wondering if a i7 4790k would give me a better performance than my i5 4460 that i currently use on my triple 1600 x 900 monitor with 2way SLI GTX 760. Could the swap vive me more FPS, is it worth it?
My built is : z97-a motherboard
I5 4460
2x GTX 760 MSI twin froz
Supernova 1000g2 psu
3x 20'' 1600 x 900 monitor
Nope, that cpu should not be bottlenecking your setup, are you trying to max out games in three monitors?
Yes, well on a couple of games i can acheive 60+ fps on a 4800 x 900 resolution by lowering the graphics just a bit but notre that much. Also having AA off helps.
4800x900 is too much for two GTX 760s, there are benchmarks at 5900x1080, something higher than your resolution, and they usually deliver around 30fps, you need to set things a little down to run games more smoothly, overclocking your gpu can also help.
