Hello guys,
I7 6900k
Asus maximus viii alpha (updated to 3703)
H440 v2 case with stock fans connected to mobo running at full speed 100%.
3 fans at front suck whilst back fan exhausts.
H105 corsair cooler where radiator is on top nd it exhausts. (Water pump running 1800 rpm full. Fans using y splitter 140mm each connected to cpu fan running full speed)
16gb * 2 corsair 2400 ram, which is set to profile 1 on bios nd I pressed yes when it asked me about Intel stock something.
1080 gigbyte Nvidia founders edition.
I went into bios changed to XMP and pressed yes.
Next I put 47 for 4.7mhz.
Next I put manual and set core voltage to 1.35.
External digi+ LLC to level 6 ( or 5 )
I am running aida64 4.7mhz at 1.392 core voltage.
15 minutes have gone by.
Mobo temp is 27 max
Cpu max temp is 63 average 58
Cpu core 1 max is 84 average 66
2 is 81 average 64
3 is 77 average 59
4 is 75 average 58
Room temp is ambient. 18-22c
A re these safe temps or should is knock back the voltage? I am new to oc. So sorry if info lack and sorry it is an old build.
Thanks.
UPDATE 11.03.2018
I have knocked it back to 1.24 at 4.5mhz External digi+ LLC to level 6 with max temps CPU core going 65. Stress Test Aida64 for 8 hours, no crash.
I have lowered the voltage to 1.23 at 4.5mhz External digi+ LLC to level 6 , once again max temps CPU core one 65. Stess Tested.
At 1.23 core voltage is 1.264 at heavy 100% load. And jumps down to 1.248.
Do you guys reckon I should go on adaptive mode now?
Or should I test 1.22?
Thank you for your time.
13/03/18 UPDATE
I went back to 4.7mhz. When I play games (Like FFXV for 2 hours) max CPU CORE temp goes to 65. Then again my H440 Stock fans are running at full speed, along with my water pump and 2700RPM cooler fans + GPU fan at 95%.
It passed Realbench (latest version during this present time) for 15 minutes, however my bench mark score made me want to die, hence why I have given up on "oooh too much volt means too much temp" if it dies i'll feel apart of me has died (Which would be a good thing), and when PC parts go down, and when BITCOIN dies down, hopefully I'll be in a position to build a new rig.
I'll still be keeping a track of this thread in case someone can give me some optimal advice.(I have the google chrome extension).
Thanks in advance.
I7 6900k
Mobo temp is 27 max
2 is 81 average 64
3 is 77 average 59
4 is 75 average 58
Thanks.
UPDATE 11.03.2018
13/03/18 UPDATE
Thanks in advance.
