I7 6700k idle and load temp problem?
jjs1107
30
Hey everyone just put a new i7 6700k in my system and noticed that when I rendered a video the temps jumped to 100C. In idle they are anywhere from 29C-38C. Is it running hot?? I feel like it shouldn't do this.
I am running the Coolermaster Seidon 120V as a cooler and it worked really well for my 4790k which was at a 4.5 ghz overclock.
Asus Z170 Pro Gaming Mobo
It is in a phanteks enthoo pro.
asus Gtx 970 strix
Corsair 750m psu 80+ bronze
Doubtful with an Intel CPU. Try HwMonitor and Speccy
Right Its mounted right and the idle temps are good. I am more worried about load temps.
Your load temps suggest it isn't mounted right or one of the connections isn't right.
At 100C your PC should have hit the thermal wall and shut down.
Would it be that the temperature monitor is bad? I am using the MSI Afterburner software.
