Hello there,
I've recently upgraded my internet to 1000 mbps, however i can't reach a speed higher than 750 mbps. I've checked and rechecked all the hardware, and then recently realized that the speed stops going higher when one of the threads (CPU 0) reaches 100%. Understandable, however what i don't get is why it doesn't use other cores as well. I've tried making windows boot using all 8 threads however that didnt change anything, and i've also checked the affinity of chrome, it s set to use them all by default. I can't think of another way to fix this which is why i'm here. Any advice? I should also specify that what i found weird is that the first time i connected using the new speed, i ran a speed test and it did reach 990 mbps, so this is weird. The connection is through PPPoE throguh fiberlink (no router) but i doubt that's relevant
Thanks for your help in advance!
CPU: i76700k
MOBO: Maximus Hero Alpha VIII
Cheers!
CPU: i76700k
Cheers!
