I just finished putting together my new Z170 i7 6700K PC and looked at my CPU temp only to see that I'm idling (1-10% load) at 45C. I have a Noctua NH-14 which was keeping my 3570K at about 25C idle. Right now my ambient temp is about 15C and my mobo is at about 20C. 45C seems way too high for my CPU to be idling at.
I've reseated the NH-14 twice and I'm using ArctiClean (and used it initially when cleaning off the old compound that was from 3570K use) to clean and prepare the mating surfaces and it doesn't seem to be helping. Is there something I don't know about the i7 6700K? Is it THAT hot of a processor? My only thought is that I've somehow damaged the cold plate by using a cloth instead of coffee filters or something. I'm using the pea method for applying the compound (which worked fine for the 3570K also). Please help. Any input or advice on the situation would be greatly appreciated.
