Hi,
I recently built an ITX small form factor PC using an i7 7700. The case has no external fans at all, only a grate about 5cm above the CPU fan to atmosphere.
I have used the Noctua LH-9i low profile cooler and I'm getting idle temperatures of around 40-43 degrees, rising to approximately 75-80 degrees when playing The Witcher 3 on full settings.
Are these temps considered to be normal for this type of build and CPU?
For reference, my case is the Silverstone MIlo ML08.
Thanks
Thanks
