S Spambotting Commendable Dec 30, 2016 14 0 1,510 Aug 26, 2017 #1 I'm getting very low fps on csgo with an i7-7700 with a GT 730. Should it be this low? And I'm On Windows 10 and this is a new gaming pc. Upgraded from a i5-4460 and a 960 to this.
nitinvaid20 Splendid Jan 3, 2013 2,708 1 21,965 Aug 26, 2017 #2 from 960GPU you got this? 730? thats not a upgrade and 730 is not a gaming PC nothing lower then x50 is a gaming .......... Upvote 0 Downvote
Supahos Expert Ambassador Nov 11, 2013 12,755 48 57,640 Aug 26, 2017 #3 You didn't upgrade you downgraded from a gaming perspective. A 730 isn't even a gaming card, a 960 is over 500% faster than the 730, Upvote 0 Downvote
S Spambotting Commendable Dec 30, 2016 14 0 1,510 Aug 26, 2017 #4 Dang umm will a 960 go along with this doe? i have a biostar mother board but idk what type and idk how to find out Upvote 0 Downvote
Supahos Expert Ambassador Nov 11, 2013 12,755 48 57,640 Aug 26, 2017 #5 Actually your fps will go up a bit of you remove your 730 and use onboard video Upvote 1 Downvote
H hamster66 Reputable Dec 5, 2015 120 0 4,760 Aug 26, 2017 #6 If you still have this 960 then just replace 730 with it and you'll be fine. Upvote 1 Downvote
Supahos Expert Ambassador Nov 11, 2013 12,755 48 57,640 Aug 26, 2017 #7 Yeah if you have the 960 still use it Upvote 0 Downvote
S Spambotting Commendable Dec 30, 2016 14 0 1,510 Aug 26, 2017 #8 btw umm i tried that on board video thing it doenst give any signal to my monitor Upvote 0 Downvote
Supahos Expert Ambassador Nov 11, 2013 12,755 48 57,640 Aug 26, 2017 #9 You'd have to remove your 730 Upvote 1 Downvote
S Spambotting Commendable Dec 30, 2016 14 0 1,510 Aug 26, 2017 #10 shit i actually meant windows 7 not 10 Upvote 0 Downvote
Supahos Expert Ambassador Nov 11, 2013 12,755 48 57,640 Aug 26, 2017 #11 Will have no effect on your current situation. Other than a 7700 isn't "technically" supported with with. 7 Upvote 0 Downvote
