i7 7700K cpu cooler
Jan 21, 2019
4
hello
i have i7 7700k and coolers id-cooling is-60v2 or Antec A40 pro. case is corsair spec 04 tempered glass. which cooler is better for my CPU?
Well the Antek A40 Pro is way better than the ID 60v2, but I can suggest you one better than both, I will recommend you the Cooler Master 212 Evo it has direct contact to the CPU and its very efficient even for overclocking higher CPUs.
the problem is cooler master 212 evo is big for my case
Ah ok then its no issue, if 212 can't be fitted inside then go with the Antek A40 its vertical and it has a better heatsink and it will transfer heat way better than the 60v2 which is laid horizontally down = not good.
Well if I helped you somehow with this, will you consider to chose this as a closed thread and chose one of my answers as Solved. Ty. Ask any more questions if you need answers to anything more.
Yes, it's better than the EVO 212 or more or less here and there, but it's high as same as the 212 Evo, he says he cannot add it in his case that much high coolers.
according to the case size maximum cpu cooler height is 150mm....is cryorig H7 better then antec A40 pro with 4 heat pipes?
Both of them will perform very well, in these 2 coolers there is no worst-case scenario. Just check them online how much is their length.
A40 Pro Specification: Fan Dimensions: 92 x 92 x 25 mm. Fan Speed: 800~2200± 10% RPM
Hyper Evo 212 = 120 x 79.7 x 158.5 mm
Cryorig H7 it has hight of 145mm
And your case is 15cm and the Evo is same just like 8mm more in which when you close the case the case itself will easily lay on it. I bet 100% that if you have 15cm space you can add the Evo 212 and in all these cases 212 Evo it's the best recommendation from me.
I hope this helped you.
This is just my personal recommendation as SkyNetRising said the H7 is better and it has a larger sink if you want to go with it, and its 145mm which will fit in your case for sure.
i`ve bought hyper evo 212, thank`s a lot
Nice I hope it runs good for you, so if you found the answer good and if helped you will you chose it as a SOLVED thread. Like pick as a solution an answer.
