i7 7700k hot hot hot w/ h100i v2
RyanKruMP
Commendable
Nov 11, 2016
80
I resat it and made sure it was tightly in, holding the screws on the backplate down to ensure a snug fit, did a stress test on intel diagnostics thing and 4.8ghz 1.3v it hit 99 in 8 seconds and I cancelled it, going to take it off again and see if the thermal compound is getting to the heat sink, if it doesn't then I'm not sure why it's not connecting to the CPU tightly
RyanKruMP
Commendable
Nov 11, 2016
80
The little standoffs that are used for the screws on the backplate don't touch the motherboard leaving room for it to jiggle could that be why I can't tighten down my heat sink all the way to make the connection perfect to the CPU? Or is there suppose to be a little gap
Irlvexed
Commendable
Mar 2, 2016
59
Perhaps you're using the wrong standoffs, the h100i v2 comes with 3 different sets
Irlvexed
Commendable
Mar 2, 2016
59
I was having a similar issue with mine, couldn't hurt to be positive on that though, would suck to have gone through all of this for it to only end up being the wrong standoffs lol
RyanKruMP
Commendable
Nov 11, 2016
80
Yes and I think I figured it out, with my case back window the backplate is being blocked from being pushed out on my side leaving that side from getting even connection with CPU, I might have to install with motherboard loose or out then put it in the case
The_Staplergun
Estimable
Jan 30, 2017
1,395
214
For some reason my h115 came with three sets where the one end on each set had different threads. It didn't even make sense as there was only one set that actually screwed into the threads whatsoever.
It should seat all the way down in it. Just get the backplate in behind the Mobo and the standoffs on the other side. It'll be slightly loose. When you tighten down the cooler it will snug up.
RyanKruMP
Commendable
Nov 11, 2016
80
No it's my case, watch the video, the backplate doesn't fully fit to the holes I have to push the mobo forward to get the one part of the backplate in, so when I go to put the cooler on it get blocked from the case and that side doesn't get full contact hence why my thermal compound is half on, I don't know how I can use this liquid cooling with my case it doesn't work out
The_Staplergun
Estimable
Jan 30, 2017
1,395
214
That's how loose mine was. You need to use the standoff that has the same threads on both ends, if you're not. Theres one with short tip but wider thread that doesn't fit and one with wider thread that doesn't fit right. Screw it all the way down and then pull on the standoffs a little to pull the plastic backplate through all the way. Then screw the cooler on.
This is where it's important: start a single screw and give it one turn on so it doesn't pop off. Then start the opposite side just as much. Then get the other two on and then snug it all down in the same order.
Once all four are snug. Thumb tight then grab a screwdriver and give them all a few extra turns.
If you are tightening one side all the way down, the opposite corner thread might not be catching and it could be cross threading which makes it not go down and it gets stuck much earlier than it should.
When you put the cooler down in the socket, you try to push it down flat. Once you start a screw you have to keep one hand on it pressing pretty hard. Not hard enough for the Mobo to flex but you need to keep substantial pressure on the cooler head until all four screws are thumb tight.
RyanKruMP
Commendable
Nov 11, 2016
80
I know all of that, it's my case blocking my backplate from letting the heat sink fully sit on the right side that's all, I know the proper way to do it
RyanKruMP
Commendable
Nov 11, 2016
80
http://m.imgur.com/UFuFo8a See my case blocks the left side, in which I have to dig it in under my case and push my mobo out to get it in, so after it blocks from pushing back out when I put the heat sink on so it doesn't full sit on that side and that's why I'm only getting half the heat sink with thermal paste on it
The_Staplergun
Estimable
Jan 30, 2017
1,395
214
You didn't install standoffs on your motherboard?
Ohhhhhhhhhhhhhh. I get it now.
You did install standoffs right? The motherboard isn't really supposed to screw directly onto the case. It could cause electrical shorts if something grounds against the metal.
I'd strongly encourage you do if you did not.
You COULD do it that way, but that just brings that metal case into the back of the motherboard harder, which could cause a short at some point in the future.
