Hi All,
I've read so many posts about this before but was wondering if any one could provide some insight for me anyway.
I have a 7700k which is idling at 55 degrees Celsius which seems super high and when running games like pubg or rainbow six siege it averages from around 75-92 degrees but usually sits around the 85 mark. I know 85 is semi-safe but it still boosts over 90 while playing games. I have set manual voltage to 1.2 down from 1.28 and I have also tried setting it to 1.15 but it made little difference.
I was running games a couple of weeks ago at around 55-65 degrees, then all of a sudden it was burning up - updated bios which fixed issue for a few weeks... now all of a sudden its happening again but not BIOS update is available..
I haven't tried re-applying thermal paste or resitting cpu/cooler for cpu yet but it seems like it wont fix the issue.
(Also this is all under 50% load... i get around 85 degrees at 35% load)
Current build:
I7 7700k at clock speed 4.2 with a voltage of 1.2 from mobo
H100i v2 Corsair water wooling (replaced stock fans with corsairs HD120 rgb fans used as exhaust on top of case)
1x HD120 corsair RGB fan in back of case as exhaust and front of case is 3x LL120 RGB corsair fans
Gigabyte z270x mobo
Gigabyte g1 gaming 1070 GPU
Typical sea gate 1T HDD and samsung 850 evo 500 gig SSD
2x 8 gig sticks of 3200 mhz g.skill trident RGB ram clocked at 3200 (enabled XMP profile)
Corsair 570x RGB gaming case
Current build:
Gigabyte z270x mobo
