[SOLVED] I7 8700K 4.7 all cores overclock help
kiwi1994
4
Hi all, I am very new to OC and would like to OC it to 4.7 for all cores.
Below are my specs:
nzxt kraken x62 aio cooler
intel i7 8700k 3.7ghz
asus rog maximus x hero
gskill trident z rgb 3200mhz 32gb kit
samsung 960evo 500gb nvme m.2
toshiba 2tb 7200rpm
asus gtx1080ti o.c edition
superflower leadexii gold 850w
win 10 64bit
More than agree with thtran6...The 8700K should overclock to 4.7GHz with just a simple change to the multiplier to 47 in the BIOS and leave everything else on auto but it will tend to give a bit more vcore...There are some great guides especiallyt for your motherboard on the overclocking setup through the BIOS...
de8aur is the best:
https://www.youtube.com/watch?v=CoUtA7DKXhU
https://www.youtube.com/watch?v=pbRauc8gpQM
but there are so many...
With those specs I certainly think you can even go above 5.0 Ghz all cores (might get a little hot for that x62 though, but certainly can).
You would do it via your BIOS.
Since you are first time, I would suggest watch several Youtube videos with your specific motherboard or a similar one.
de8aur is the best:
but there are so many more....
