Hi guys,
I have an intel I7 8700K mounted on ASUS Z370-E Gaming motherboard with a Cooler Master MasterLiquid 240 Pro AIO cooler. I tried running 4.7Ghz on all cores. I set my VCORE to Adaptive mode and a value of 1.2 V, Load Line Calibration to 4 (with 3 it fails in Prime95 10 sec into the test). I maxed out the power and current limits. Now when i run Prime95 Small FFT test, i get 4,7Ghz at first, but it drops to 4,6 and remains there, with the test running stable. Looking in HWiNFO i see "IA: Max Turbo Limit" set to YES. There are no other events (no throttling due to temperatures or power draw). The CPU temperature never goes over 79 degrees during the prime95 test. What could be causing the CPU to throttle down to 4,6Ghz? I attached a screenshot from HWiNFO.
