I7 8700K air cooler for 4U case
Apr 18, 2018
I'm building a machine for video streaming encoding, using an I7 8700k on a Gigabyte Z370 motherboard. I'm not going to be overclocking this system, and it will have no other uses than encoding. I've an older 3970K system it will replace that currently doesn't go over 35-50% proc utilization while encoding, so the load should not be that heavy.
The problem I'm having is lack of space. I need a good air cooling solution that is less than 154mm or so, that can still clear the heat sinks on the motherboard, ram, etc. I'm not seeing a lot of options so far.
Thanks in advance!
CRYORIG H7 as long as your not overclocking.
145mm tall.
Best budget cooler on the market.
Image from: techpowerup.com
http://www.hitechlegion.com/reviews/cooling/heatsinks/42980-cryorig-h7-universal-cpu-cooler-review?showall=&start=3
Review from hitechlegion ^
[video="https://www.youtube.com/watch?v=kNF-GHQthro"][/video]
Simple installation video here ^
Unmatched Compatibility
Zero RAM Interference
Focusing on providing the widest range of
compatibility, the H7 utilizes an asymmetric slanted
heatpipe layout to move the heatsink away from the
RAM zone, Offering optimal compatibility for RAM
with tall heat spreaders on both Intel 115X and
AMD platforms.
Dark Lord of Tech
Retired Moderator
145mm tall.
AMD platforms.
Image from: proclockers.com
[video="https://www.youtube.com/watch?v=KrROVq0cdCY"][/video]
