I7 920 build need help
billiam111
33
Right now i got an amd pc, so im going to build a i7 920, but i need some suggestions for motherboards
my price limit is about 1200$
All i really need is, i7 920, motherboard, ddr3 ram,
i already have a 9800gtx+, and i want to get a second one, so i need a psu with 4 pci-e 6 pin connectors
i need to know a psu that can support the i7, motherboard, 2x9800gtx+ 500G HDD, ddr3 ram
suggestions please
EVGA motherboard is excellent for SLI:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188046
ASUS p6T is also a good choice and cheaper:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
Corsair TX 650 or 750 are both great PSU's:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Use a PSU calculator to find out how much juice you will need - and remember to include overclocking if you plan on it:
http://extreme.outervision.com/psucalculatorlite.jsp
