Negative, and why the 9700K? Do you already have a Z390 board?
If you don't, then I'd point you to the 10600K and Z490 - still can't get a cheap cooler for it.
Air: Depends on the available chassis clearance, if you can provide that, please?
Liquid: 240mm or larger.
Well, if you want to get more performance, then you either want to overclock, or at least use the one button OC, a-la, All Core Enhancement.
Freezer 7 Pro won't cut it, even at stock.
And just to shoot this down before it even comes up: Not even the popular Hyper 212 is enough.
The liquid cooler recommendation is easy enough: a 240mm or larger.
But if you'd rather use an air cooler, I'd need to know how much clearance is available in the chassis.
"Ippon Thor" is my chassis make and modelIf you can provide the make and model of the chassis, I can look it up.
Imma need some help with this one. I can't find the cpu cooler clearance listed.Ippon Thor
