I7 build, need some help
cb89109
6
I need some of your help. I was wondering if there was anything I could change to knock the price down on this set up. I might just keep one of the video cards until I can afford the other one. Also wanted to know what is a good cheap tower for everything. Thanks for your input.
Intel Core i7 920 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819115202 $288.99
EVGA 132-BL-E758-TR LGA 1366 Intel X58 ATX Intel Motherboard - Retaill
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188046 $254.99
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6820231247 $89.99
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822136319 $74.99
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6817139006 $124.99 - $20.00 MIR
EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130475 x2 $499.98
LG 22X DVD±R DVD Burner with LightScribe Black SATA Model GH22LS30 - OEM
http://www.newegg.com/Product/Prod [...] 6827136153 $25.99
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6835233029 $39.99
ARCTIC COOLING MX-2 Thermal Compound - Retail
http://www.newegg.com/Product/Prod [...] 6835186020 $6.99
Microsoft Windows Vista Home Premium
http://www.newegg.com/Product/Prod [...] 6832116488 $99.99
sheppyb
19
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
$74.99
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
$119.99
The psu if fine for 2 of those cards. Even SLI'ed 285s in a i7 965 draw less than 500W total.
http://www.anandtech.com/video/showdoc.aspx?i=3517&p=13
That psu looks like an octopus too with all the connectors. I personally opted for a quality modular design from Silverstone.
fullmetall
1,698
Would go for an rc-690 at the best, missed yesterdays deal on it though, was $25 off.
psu is fine powering 2 285's idk about that though. seems pretty iffy.
would rather go 850tx than 750tx with 2 285's.
cb89109
6
On this site it says that the load for the cards is around 400w roughly. If I have 2 of them installed do I need something to handle them both or does it load then move on to the next item to load? If that makes sense. Thanks for all the help people.
xthekidx
Splendid
Dec 24, 2008
3,871
I think you are confused. Load power means the amount of Power those GPU's consumed when they were fully loaded (ie under the most strenuous conditions). Its not loading, like as in loading a level on a game or booting from a hard disk or something.
cb89109
6
Oh ok. So it would be ok with this psu then. Or just be safe and get a higher one you think? I don't really know. What happens if there is a need for that wattage but my psu only goes to 750w, does anything get messed up?
