OK so i built a i7 920 with the intel DBXso board 3gbs of ocz reaper memory. i am using the H50 water cooler and im getting temps of idle at around 45 to 55. I have replaced the thermal paste from stock to artic silver, had two other pc builders look at the computer as well as replace the thermal paste. I over rode the fans in bios so that there on full blast and still im seeing temps in the high forties. I have done other builds for people and i get temps of around 27 to 33 with the same cooler. Could my processor just be defective, i am not a over clocker i did scale the memory up to 1666 but after the heat issues i took everything back to default settings. The one wierd thing i noticed is that with the on board messing system from intel i am allways running at about a 20% load. does anyonehave a similar setup or know if any reasons i may be doing something wrong or is my processor just defective. Any help would be greatly appreciated thanks
