I would like to upgrade my stock cpu heatsink/fan but do not feel comfortable removing the MB to put in a backplate. Can anybody recommend to me an upgrade that does not require this? thanks in advance, jerry
What case do you have? Does your MB tray have a cut out behind the socket? I upgraded my HS all I had to do it remove half of the screws and loosen the rest and the HS bracket slid inbetween the tray and the MB. it was easy!
