I've been asked at work to spec up and build a system for use with Flash CS4 64-bit. The current 32-bit XP system is crashing due to memory issues so i've been tasked with coming up with a system that won't have memory issues, hence the i7 \ 64-bit direction. The OS will also have to go to Vista Business too, as our network doesn't support Home versions of Windows.
I've got a budget of around £1500 give or take a few hundred and need to have something tailored to do the job well. The most important features of the system are going to be reliability and warranty should anything go wrong.
I'm a bit unwise on graphics and hard drive requirements of Flash, if any at all. I'd like to have as much of a cool and quiet running system as possible as i know the user will only winge if theres a PSU\cpu cooler in there that constantly sounds like a jet taking off, and i know he'll leave it on for unnessicarily long periods of time too.
Any and all advice welcomed.
Ross
Ross
