Hi,
I'm relatively new to hardware;
System
i73770k (not overclocked)
z77 sabertooth motherboard
silent eagle 1200mm (i think) closed loop liquid cooling
16gb ram
gtx 680 4gb
Problem:
CPU is liquid cooled by 120mm Liquid cooling silent eagle closed loop cooling system,
Its idle temp is between 35-41 (which I think is high)
Playing battlefeild 4 I get temps of around 72 degrees to 80 degrees
doing research I know this isnt safe at all (it could burn out my CPU), I dont understand what I can do to lower this.
The fans on the liquid cooling system seem to be fine, and are running as usual.
Possible solutions I have thought about:
(i dont know if thermal paste has been used already, Im assuming so) to use new thermal paste (good quality)
Get a completely new cooling system.
I really want to reduce the temperature if you have any knowledge of how to do this it will be really
Thanks
System
16gb ram
gtx 680 4gb
Problem:
Thanks
