Hi I have a new i74790k from amd fx8320 but i'v have searched around with temp guide's but nothing that can help me with this issue.
When i stresstested it for 1hour my temps for the cpu are 85c Max on 1 of the core's, but the heatsink is cold, i know with amd that when it is at 60c the heatsink is at near the temp, but with the intel its as cool as room temp.
Note: this is just the cpu if i factor in gaming or using gpu aswell as the cpu it could get higher.
And yes I have redone the Paste twice and no change, i'v used arctic silver.
My Heatsink is: Hyper 212 EVO same cooler what i used on my amd cpu.
I have a possable aswner for this issue, my guess is that there is not enough contact from the die to the heat spreader, because intel is kind of known with cheaping out on stuff like that with the sandybridge generation.
Ok the CPU's life story is here is this normal?
Thanks 😀
Thanks 😀
