Hello All,
My trusty 4790k has been giving me issues as of late, or so I think. I started having PC issues as of late and ended up with my OS getting corrupt. Ran a full panel of hardware tests (Memtest, chkdsk, antivirus, PSU test, Mobo Test etc) I work for an IT company so I've got a pretty full suite of diagnostic and repair tools at my disposal, everything came back clean, except for CPU Temps they spiked all the way to 80C during the diags. I reinstalled win10 and everything seemed stable again.... Time to figure out these crazy high temps.... Ran prime95 Smalls test, after 3 seconds I was already at Tj Max. Time to clean out the cooler and apply new thermal paste I thought, did that.. about 4 times, everytime the same result, faulty AIO I thought.. so I buy a new one.. install cooler again... nothing changes.. pseudo stable system.. however prime95 smalls test still reaching 100C within seconds... reinstall cooler and reapply paste 3-4 times... again same results.. I'm at a loss here guys... Vcore temps are normal... voltages are stable from PSU... I really don't know whats going on... I need some help figuring it out... here are system specs and test screenshots.
Processor did have a mild overclock since this rig got put together( 4.0ghz to 4.5ghz) Temps never went above 65C after 8hrs of prime smalls for heat-
or during 48hrs of prime95 Blend for stability.
CPU - Intel i7-4790k
Cooler - Corsair H80i replaced by Deepcool's Captain 120EX
Core speed - 4.0 Current (4.5 in the past)
Core voltage at load - Vcore 1.072
Load test software - prime95
Temperature software - HWMonitor
Load & idle Core temperatures - Load 100C - Idle 35C
Memory Corsair Vengeance DDDR3-
Motherboard - MSI M87 (MS-7815)
Graphics Card - XFX AMD R9 290
Ambient temperature
Edit: 74F/23C
https://imgur.com/a/fTJEVyj - take during idle moments --
in that screenshot the Max numbers from HWMonitor are after 3 seconds of prime95 Smalls test, Thanks in advanced for all the help.
Ambient temperature
Edit: 74F/23C
