Question I7700k need help
Apr 17, 2019
42
Hi guys I’m new to pc so please be patient and bare with me.
I have a i7700k cpu and h100i Corsair Cpu cooler.
I have OC my cpu and these were my results
5ghz 1.35v
91 degrees
70 with 10-15 percent load
4.8ghz 1.30v
87 degrees
65 idle
At this point I think I may have to re thermal my cpu and fitter the AIO? What would you guys suggest as these are poor results.
the max temps were on prime95 max stress test.
You are a bit ambitious with your clock speed for prime 95. Prime 95 uses avx and runs really hot so for prime 95 i wouldnt expect 5ghz. I would say the cooler is fine, just not enough to get to 5.0ghz. I would set the speeds a little lower and make sure temps are under 80c while gaming.
Apr 17, 2019
42
Thanks for the reply. I have seen quite a few people with a h100 I getting 5ghz with decent temps. But surely I shouldn’t be reaching 90/95 degrees my cpu even on 4.3ghz ram In the mid 80s
Thread starter Similar threads Forum Replies Date
S Overclocking 20
M Overclocking 11
R Overclocking 5
Similar threads
