[SOLVED] i9 10900 vs 10900k Need Help
geofelt
Good luck on finding a i9-10900K in stock.
If budget is not a problem, go ahead and buy the 10900K.
It is a better binned chip and will turbo up a bit higher to 5.3
If you buy a high end Z490 based motherboard you will have more options and the ability to overclock later should the need surface.
Still, the i9-10900 is a very strong processor.
For that, you might want to save a bit on the motherboard and use the budget elsewhere.
Lutfij
What will you be taxing the CPU once the system's built? I'd get the non K version if you're not going to overclock. You will also be able to pair the non K processor with a non overclocking board but keep in mind that if you want to overclock rams, i.e go beyond DDR4-2933MHz, you're going to need a Z490 chipset board as opposed to a H470 board.
geofelt
