Question I9 12900k FPS very inconsistent Looking for some help on why
May 2, 2024
Specs
CPU: I9 12900K
Ram: 3200Mhz 2 x 16 gb Corsair Dominator
Power Supply 850W Corsair RM850
GPU:RTX 3090
CPU Cooler: Corsair H100i 240 AIO
2 AIO Coolers in a Pull Manner
Case: Lian Li O11 Vision Tempered Glass
4 Case Fans Exhausting
XMP is enabled
Turbo is enabled
Fresh windows 11 install
No RGB programs
Pushing 200-270 fps in Valorant when I watch other benchmarks they usually get upwards of 350-400 and I am not sure what the reason is3
I do have gsync enabled and Vsync to utilize both but my FPS is very different than what I expect can anyone help me.
Lemme guess YT.
Make and model of your motherboard? BIOS version for your motherboard?
You should've looked into buying a 1KW PSU instead of an 850W unit.
Where did you source the installer for your OS? Did you install the OS in offline mode? Manually installing all drivers in an elevated command, i.e, Right click installer>Run as Administrator?
You should've gone with a larger radiatored AIO, something that was 360mm.
Lemme guess YT.
Yeah YT videos but even then 12900k pushing 200-250 frames when i used to get liike 300-400 frames idk what happened recently
Make and model is pro z690 a
MSI PRO Z690-A LGA 1700 ATX
Bios version
BIOS Version/Date American Megatrends International, LLC. 1.00, 9/14/2021
The installer I just used the Windows 11 USB Installation creation tool
https://www.microsoft.com/software-download/windows11
I didnt install in offline mode nor and extyra drivers in elevated commands
CPU Cooler was a past decision wont go with water cooling in the future.
