Question i9-12900K temps, am i fine or should I worry about it ?
para123
38
  • i9 12900K
  • msi z690 tomahawk wifi ddr4
  • msi gtx 1060 6gb ( will get rtx 3070 ti soon)
  • noctua nh d15 chromax
  • corsair 750w TX M
  • corsair airflow 4000d case with 3 intake fans at the front ( corsair 120mm levitation fans ) and 2 at the back of the case.
  • windows 11 pro
All i did is i updated bios and i set power plan to "maximum performance" in power options setting, literally everything else is set to default.
When idle my temp is 30-31C, gaming temps are 49-55-65-67C (depends on the action in game), and while streaming my temps are around 69-75-82C
Am i fine with this temps? Or should i worry? Do u think an 360mm AIO would make a significant difference? I stream via cpu (x264) since my old gtx 1060 is crap, im gonna switch to NVENC gpu encoder when i get 3070 ti
