Hey All,
Hoping someone could help me out here as I'm a bit lost. I recently built a new PC for myself, first time I've done this and was happy to get it working.
I decided to do some benchmarking and the results were great but temperature for the CPU is a concern. Spec is as follows:
i9 9900K 8 core 3.6GHz
RTX 2080 TI
Gigabyte Z390 Gaming SLI
Corsair H100i Hydro PRO
NZXT H500 Midi-Tower Case
At idle the CPU runs at 4.7Ghz. Idle temperture is 40-45.
I ran Prime95 with Small FFTs. Within seconds of running this, the CPU hits 100 degrees, and naturally throttles repeatedly.
I've tried cranking up the H110I, by default it's on balanced. Even with putting it at Performance it has no impact on the heat.
I've removed the water block, cleaned it and the CPU of thermal paste and reapplied new paste. I double checked the water block was fixed properly.
I am looking for some suggestions on what might be the cause here and what I could do to try and address it.
Could it be the case isn't suitable? As it's a sealed front case (not detachable), I have the radiator mounted on the front inside with fans pulling on the front of the radiator - This case is designed with mounting the radiator there and as such has a grill on the front side. There is a back fan and a top fan pushing air out.
Is it because there is something wrong with the cooler? The pipes feel warm to touch and there is noise there showing activity. Corsair Link reports what appear to be accurate values and such.
Any help would be much appreciated.
Thanks.
CPU-Z Screenshot: https://imgur.com/a/DFgFRXS
Intel Extreme Tuning Settings Screenshot: https://imgur.com/a/BXb9qSW
RTX 2080 TI
Thanks.
