Archived from groups: comp.periphs.printers (
More info?)
Have you find many sources for Formulabs ink. alotofcrap is not a source.
Taliesyn wrote:
> Ron Baird wrote:
>> Greetings Taliesyn,
>> Just curious if you are using the suggested settings on the Kodak
>> site for
>> your particular paper. Also, are you using Canon inks. If so, you
>> should
>> be getting great results with that paper. Give the paper a try after
>> adjusting your settings. If still not good let me know and send me a
>> sample
>> and I will review for you.
>> Talk to you soon, Taliesyn,
>> Ron Baird
>> Eastman Kodak Company
> Greetings Ron,
> Sorry, I don't mean to slam Kodak Premium Paper but it just doesn't
> perform, look or feel as good as most of my other papers.
> From the Kodak website the recommended settings for my Canon iP5000 are:
> "Other Photo Paper", Print Quality: "High", Color Adjustment: "Manual -
> Magenta -10, and Yellow +5".... Not my usual settings, but I tried them.
> The results are totally unacceptable - Strong head pass lines visible,
> quite washed out, speckled (very visible dots). The only recommendation
> that makes any sense is the Magenta -10, and Yellow +5 suggestion.
> I've run various tests on it earlier (on an i860) and didn't like the
> results very much. And today on the iP5000 I tried again. And no, I
> don't use Canon inks, they're made by Formulabs. If you're about to
> suggest that my inks may be in conflict, I won't buy that for a moment
> as they produce great prints with all other papers - even Dollar Store!
> I tried several settings with the paper and the only one that produces
> the most satisfactory print is "Photo Paper Pro". At this setting the
> result is still visibly poorer than the excellent result produced on my
> Dollar Store paper (not my favorite paper). I know that sounds like an
> insult to Kodak, but Kodak will have to get used to it as more and more
> inexpensive papers arrive on the market from places like China (mine is
> sold as Likon brand). The Likon print seems to have perfect contrast
> (the Kodak is a bit washed out like there's a film over it), the blacks
> are blacker and shows absolutely no visible print lines when the photo
> is turned sideways, whereas the the Premium paper shows lines. This
> Likon paper actually prints as good or better than Canon Photo Paper
> Pro. It's not instant dry (24 hrs recommended), but it works great. My
> preferred paper right now is Costco's Kirkland Professional Glossy
And who do you think makes Kirkland?
> . And
> I do understand that this Kodak Premium paper is not Kodak's best.
> As for the other settings tried (compared to the Photo Paper Pro
> setting):
> Plus Glossy - Not acceptable - very visible print lines, speckled and
> slightly more washed out.
> Glossy - a bit less of all the bad characteristics of Plus Glossy.
> Other Photo Paper - Do not use, the worst setting of the bunch.
> I do have Canon OEM ink that I could also run these same experiments
> with. But the ink I use is perfect with all my other papers - no
> horizontal print lines, perfect contrast, unspeckled clarity, etc.
> I really see no point in chasing my own tail any longer with settings.
> I've already done these same basic tests now on two separate printers
> and the results are the same. You claim it should give great results.
> Maybe someone, somewhere, on some other brand printer. But my basic
> tests don't agree with your generous assessment of Kodak Premium
> Picture Paper. I have used Ultima (once), and from recollection I
> found that to be OK.
> -Taliesyn
