Iastor.sys DRIVER_IRQL_NOT_LESS_OR_EQUAL
goofysmug16
Hi I am seeking help, I am encountering iastory.sys Driver_IRDL_NOT_LESS_OR_EQUAL problem. I tried system restore, loggin in to safe mode but I cannot login (normal mode and safe mode). I did the viao diagnostics, all test turned out okay.
how do I proceed with this? please help.
Definitely saw an issue related to Drivers for 'iaStor.sys' on the HP model 6730b laptop. If the Driver on your system is version '8.6.0.1007', and this can be found using [Start] > Programs > Accessories > System Tools > System Information, then 'Components' > 'Storage' > 'IDE', you should consider the update from HP's site.
I ran into an issue where the User was seeing a Blue Screen with 'STOP:' message and the code 'D1' in the Hex part, and HP specifically covers this in the 'Revision History' of the available Storage driver.
