IBM T41 hard drive noise (Hitachi Travelstar 40GNX)
G
Guest
Guest
Archived from groups: ibm.ibmpc.thinkpad,comp.sys.laptops (More info?)
My T41 has a Hitachi Travelstar 40GNX (IC25N040ATCS05) hard drive.
Otherwise I'm very happy with the laptop but the hard drive is making
too much noise for my taste especially during heavy load.
Unfortunately it also makes annoying clicks and other not so loud
noises while (almost) idling. The laptop is about 8 monts old.
I guess the problem is in the drive and not in the laptop body design.
Does anyone else have such experiences with the said drive or T41? Is
the noise a feature of 40GNX? Would some other hard drive be quieter
inside the T41?
Thanks in advance for your help.
- Mikko -
G
Guest
Guest
Hi Mikko,
I have an IBM T40 with the exact same hardrive.
The harddrive was designed to be a high-speed harddrive (and it _is very
fast) : it spins at 5400rpm and has a pretty big buffer. At the time,
though, 4200rpm harddrives were almost silent.
When I got my T40, I was surprised at how quiet it was - compared to any
laptop I'd ever come across before. It is still that quiet, but compared to
newer laptops (my sister has just got an R52, and a friend, an iBook, as
well as the thin Sony Vaio (can't remember the name)) - it is noisier. It
comes from two sources - the processor and the harddrive.
With age, hardrives get noisier - but this shouldn't be a problem with yours
just yet. The clicks are normal - the harddrive is accessed on what seems
like a random basis by windows - this is especially noticeable when you're
running low on memory. The loud click is the drive parking - this is
normal. The problem is - Objectively - how loud is it?? If it really is
loud (maybe try comparing it to another laptop) - the harddrive could be
about to go?
Try setting the harddrive to switch off after 3mins (battery scheme
settings), and seeing how quiet it is then - you may find that it isn't that
much quieter, and therefore not worth replacing the harddrive. (NB - it
often takes much longer than 3 mins for the drive to stop - because windows
is almost always accessing the harddrive - try resetting the computer, not
loading any applications and not being connected to the internet). When I
do this on my laptop, it makes it eerily quiet!
Duncan.
"Mikko Suniala" <suniala@wowmail.com> wrote in message
news:17134182.0411170503.5a0d0660@posting.google.com...
> inside the T41?
> - Mikko -
G
Guest
Guest
"Duncan J Murray" <duncan.murray@remove.this.bit.medical-school.and.this.bit.oxford.ac.uk> wrote in message news:<cnfnuo$qb2$1@news.ox.ac.uk>...
I don't remember the hard drive sound bothering me when I got the
laptop so I was wondering if the noise could have increased since. But
I guess not. The processor fan noise of T41 (while the fan is actually
idling, an issue which has been discussed thoroughly on many forums)
was an annoyance at first but now I just seem to ignore it.
> about to go?
I suppose it is just typical noise for this drive. It does not hurt my
ears but I've also come across laptops with much quieter drives. I
just wanted to figure out if other people's similar drives also make
noise or is it just mine.
Thanks for your reply, although I was kinda hoping there was something
wrong with my hard drive... you know, with the warranty and all. :)
Well, maybe after a year or so I'll by a bigger (and quieter) drive.
- Mikko -
G
Guest
Guest
> - Mikko -
Na- the harddrive's great! I have only a 1.3Ghz processor (which means I
don't have the fan problem - low power), and the high speed harddrive more
than makes up for it!
Duncan.
G
Guest
Guest
I recall reading somewhere that this is a known problem. Maybe you
should search Google...
G
Guest
Guest
Richard Grossman <rgrossmanDELETE-THIS-PART@techIII.com> wrote in message news:<DPWdnU0X7Mb64QDcRVn-vA@adelphia.com>...
Actually I did search Google (without success) before asking.
Sometimes finding things with Google can be a real pain. Sometimes
it's just hard to figure out the right words for the search but
sometimes even the right words don't help. Trying to find reviews of
products usually results in tens of pages that say "be the first one
to write a review" (or something like that) and nowadays even pages
with fake reviews. Of course I realise that this in not Googles fault.
BTW, is there a website that would do in-depth reviews of laptop hard
drives? Something like Storage Review (unfortunately they don't review
laptop drives atm).
Anyway, I also got two private mails about the noisiness of the 40GNX.
I clearly am not the only one to have noticed this problem. Thanks,
everyone.
- Mikko -
