Icon problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsme.general (More info?)
My icons on desktop have suddenly refused to be moved, and they've changed their identities in my taskbar. Solitaire icon is now appearing in front of the DVD Shrink program, Yahoo has the winZip icon, and so forth. The icons aren't representing what they are supposed to be, although clicking on them in front of their new locations does bring up the proper program.
I checked to be sure active desktop is working; I unlocked the icons on desktop menu, but still cannot move them. They've lined up on the left side of my desktop screen, and are somehow locked and refuse to budge.
My add remove plus program, when opened, has lots of yellow exclamation marks and very few icons representing the programs.
I was losing my old hard drive a few months ago and had the entire old hard drive ghosted over to my new one. I didn't do it by myself as it needed a new motherboard and power supply, so I had the machine rebuilt by my techs whom had built my present XP machine. The ME machine is my spare.
I run AVG and its updated nightly
Sygate is the firewall. I can't find any other that seems agreeable with my system.
I've defragged weekely, run virus scan, have a multutide of maintenance programs:
AdAware
Spybot
Spywareblaster
Registry Mechanic
Window Washer
RegistryHealer
I've got all of the most recent updates that the Windows update site offers for ME. I had been running Firefox as my default browser, but even that slowed to a crawl and then eventually, would open once, and then wouldn't open at all if I closed it before shutting down for the night. I would have to reboot to get it to open a second time. It even had begun not entirely loading when first opening it, missing task bars and features.
I've since installed Maxthon as my default browser, and my machine seems happy using that.
Would you have any suggestions of anything I might try to do to try and make repairs to my icon problem before I end up having to take the machine back to the techs to try and have them figure out what might be causing this problem?
TIA.....
Bev
G
Guest
Guest
The "icons changing randomly to something else" is actually quite a common
problem in W98x/WinME. I developed the same problem. It started with a
couple of icons changing, then more. Then the problem got worse when the
desktop would refuse to populate with any icons at all! That is when I
found and applied the recommendations in the following KB article:
http://support.microsoft.com/support/kb/articles/Q132/6/68.asp
Also.. do a google for "icons change randomly" for an exhaustive education
on the matter.
Hope this helps!
....Ogg
"caroskos" <bevcarr2@yahoo.com> wrote in message
news:ODR#I6qlFHA.1148@TK2MSFTNGP12.phx.gbl...
system.
programs:
AdAware
Spybot
Spywareblaster
Registry Mechanic
Window Washer
RegistryHealer
happy using that.
problem?
TIA.....
Bev
G
Guest
Guest
"Ogg" <sorry-nopam-wanted@anywhere.com> wrote..
> .... I developed the same problem. It started with a
Just a follow-up on MY specific case. I deleted the ShellIconCache file
that was recommended to do in the MSKB. Bootup went fine... Icons populate
fine on the desktop. But now there is no sign of the ShellIconCache file!
Interesting. According to the article, I had the impression that file was
supposed to regenerate or refresh.
G
Guest
Guest
Ogg,
It is my impression that the Shell Icon Cache would be
self-regenerating, as well. Have you looked again.....since a second
reboot?.....or refreshing the View in Windows Explorer?? Meantime, I will
do some checking.......
Heirloom, old and need a nap
"Ogg" <sorry-nopam-wanted@anywhere.com> wrote in message
news:SZtHe.2440$pH4.270545@news20.bellglobal.com...
> populate
G
Guest
Guest
It's a Hidden file.
Also note that ShellIconCache won't regenerate until you Shutdown again
(so on your next boot you should see it).
Rick
G
Guest
Guest
"Rick T" <plinnane3REMOVE@NOSPAMyahoo.com> wrote..
> It's a Hidden file.
Understood. By default, I have enabled viewing of hidden files. Search
still can't find it. I have only done ONE shutdown/bootup sequence since I
deleted the file. That is, I [1] deleted the file, [2] shutdown, [3]
rebooted. No file! Interesting.
G
Guest
Guest
The problem is very common. Tell TWEAKUI to rebuild your icons. That might
fix it. Also, delete your icon cache.
news:VpsHe.2273$pH4.242985@news20.bellglobal.com...
> on the matter.
> Hope this helps!
> ...Ogg
of
icons
them
side
hard
my
> system.
> programs:
> AdAware
> Spybot
> Spywareblaster
> Registry Mechanic
> Window Washer
> RegistryHealer
offers
have
> happy using that.
make
back
> problem?
> TIA.....
> Bev
G
Guest
Guest
>>It's a Hidden file.
so reboot and get bored
Rick
G
Guest
Guest
"Walterius" <nohow@noway.not> wrote..
I don't use TweakUI. I think I took it off for some technical reason many
years ago. But I deleted the icon cache, and the system did NOT regenerate
ShellIconCache. Interesting, eh? Maybe it has something to do with using
16bit video setting as well as disabling "use all possible colours in icons"
G
Guest
Guest
Hey Ogg,
This may be painfully obvious and already done, but, assuming you
'unhid' the files, have you done a search for the file? Maybe it was
rebuilt somewhere else? I believe you mentioned the icons on your desktop
working okay now? If so, seems they would have to be stored
somewhere.....(just a wild hair in this ol' brain <g>).
Hmmmmmmmm, I just did a search on my machine.......I don't have one
either! (spread the rumor that the <jdbgmgr> virus is responsible, we could
revive the Teddy Bear!) Checking further now.
Heirloom, old and causes trouble
news:YgwHe.2523$pH4.297390@news20.bellglobal.com...
>> might
> regenerate
> icons"
G
Guest
Guest
"Heirloom" <roland58XX@XXcox.net> wrote..
> Hey Ogg,
The only occurence of ShellIconCache is c:\MasterME\Windows0\ShellIconCache
dated July 2001. That is a remnant of a previous "backup" by the retailer -
and obviously not the file I'm looking for.
could
A-HA! You too. Excellent. Maybe the file get created only when the icon
size, rez, or colour depth changes ???
user
Splendid
Dec 26, 2003
3,943
Thank you so much for your suggestions and the links to sites that had information about the icon problems I was having. I had problems finding the ShellIconCache file, but finally located it using the search option, and deleted the file thru there. I've had the "show hidden files and folders" option always checked, but still couldn't find it.
My icons are back where they should be again, and are representing the correct programs they came with. I printed out all the directions and links and will visit the registry and make the necessary changes if it occurs again. I never knew this was a common problem
Thank you very much for your help. I really appreciate it
Bev
"Ogg" <sorry-nopam-wanted@anywhere.com> wrote in message news:SZtHe.2440$pH4.270545@news20.bellglobal.com...
user
Splendid
Dec 26, 2003
3,943
Thank you for your suggestions. I did delete the cache file and it did the trick. :)) It was a bit hard for me to find in the usual manner, so search had to do it for me....but now, everything is how it should be.
I'll look into TweakUI. I don't have that program. I'll give it a look in the morning.
Thank you again for your help.
Bev
"Walterius" <nohow@noway.not> wrote in message news:OtuywytlFHA.2180@TK2MSFTNGP15.phx.gbl...
> on the matter.
> Hope this helps!
> ...Ogg
of
icons
them
side
hard
my
> system.
> programs:
> AdAware
> Spybot
> Spywareblaster
> Registry Mechanic
> Window Washer
> RegistryHealer
offers
have
> happy using that.
make
back
> problem?
> TIA.....
> Bev
Shane
754
Something else you can try is open DDispkay Properties and on the Effects
tab, toggle between Large and Default Icons.
Shane
>> might fix it. Also, delete your icon cache.
> many years ago. But I deleted the icon cache, and the system did NOT
> regenerate ShellIconCache. Interesting, eh? Maybe it has something
> to do with using 16bit video setting as well as disabling "use all
> possible colours in icons" ???
Shane
754
<vbg> *Display* Properties!
Shane
> Effects tab, toggle between Large and Default Icons.
> Shane
G
Guest
Guest
Too many sherbets?
Mike
G
Guest
Guest
You can download TweakUI from Microsoft at :-
http://www.microsoft.com/ntworkstation/downloads/powertoys/networking/nttweakui.asp
Be sure to read the download/install instructions!!
Following warnings/notes reproduced with acknowledgement to the late
Koldbear
1) Do *not* change the first icon from "My Documents" on the Desktop tab
2) Do *not* uncheck: Search Results on the Desktop tab
3) Do *not* hide the Tweak UI icon on the Control Panel tab
4) Do *not* uncheck: Show Control Panel on Start Menu on the IE tab
5) Do *not* uncheck: Shell enhancements on the IE tab
6) To move "My Documents" folder, right-click on the Folder, and click
Properties.
HTH
Mart
<caroskos> wrote in message news:uigHH3xlFHA.2852@TK2MSFTNGP15.phx.gbl...
the morning.
Bev
> on the matter.
> Hope this helps!
> ...Ogg
of
icons
them
side
hard
my
> system.
> programs:
> AdAware
> Spybot
> Spywareblaster
> Registry Mechanic
> Window Washer
> RegistryHealer
offers
have
> happy using that.
make
back
> problem?
> TIA.....
> Bev
Shane
754
<vbg> Not far off, Mike! At the local shop (and elsewhere, no doubt) there's
a 3 for £10 deal on Stowells. The Chenin Blanc is most agreeable and I think
I'd better get another three today!
Shane
"Mike M" <No_Spam@Corned_Beef.Only> wrote in message
news:uyf1pdvlFHA.320@TK2MSFTNGP09.phx.gbl...
> Too many sherbets?
> Mike
Shane
754
Just as I was thinking 'someone needs to post the TweakUI warning!'
Shane
"Mart" <mart(NoSpam)@nospam.nospam> wrote in message
news:%23nu9PkzlFHA.3380@TK2MSFTNGP10.phx.gbl...
> Koldbear
> Properties.
> HTH
> Mart
> the morning.
> Bev
>> common
>> education
>> on the matter.
>> Hope this helps!
>> ...Ogg
>> changed
> of
> icons
> them
> side
> hard
>> techs
> my
>> system.
>> programs:
>> AdAware
>> Spybot
>> Spywareblaster
>> Registry Mechanic
>> Window Washer
>> RegistryHealer
> offers
> have
>> happy using that.
> make
> back
>> problem?
>> TIA.....
>> Bev
G
Guest
Guest
<lol> As long as you don't try riding your bike after <g>
Joan
> there's a 3 for £10 deal on Stowells. The Chenin Blanc is most
> agreeable and I think I'd better get another three today!
> Shane
