Hello,
I am thinking of going to watercooling. And i am looking something interesting, there is ID-cooling cpu pump set : http://www.aliexpress.com/item/ID-COOLING-Water-Block-Set-with-Unique-Comet-tail-LED-Lighting-High-Pressure-Pump-Copper-Base/32533726982.html?spm=2114.01010208.3.2.B2uogO&ws_ab_test=searchweb201556_6,searchweb201602_5_10017_10005_10006_10034_10021_507_10022_10032_10020_10018_10019,searchweb201603_6&btsid=8ef24c7d-0d12-4c84-9a3e-84f2c956b3f7
Anyone got specifications on this pump ?
I am going to have cpu + gpu + 2x240rads. Was just wondering if its worth to add this *CPU block* just because it has integrated pump and will add some pressure to my loop.
I am thinking of making it like : cpu => rad 1 => pump+reservoir <=(may switch those two)=> rad 2 => gpu =>cpu .
Just saw this one and tho - hey it may be a nice addition ?
If this pump fails, and the other one works will there be a prob ?
Like will this one restrict flow insanely ?
It is sure the flow will be restricted, but i wonder how much.
Also is there any prob if one pump is for x L/min and the other is for y L/min ?
How do ppl normaly add pumps, one beside each other or in different paces of loop, to keep the flow *constant* ?
Same GP/min(L/min) ?
