Hi guys,
I have a problem and I hope you guys can help me. By mistake, I purchased an Sony IDE DVD burner/writer with no cables from a discount store in Toronto. I can't return the item. I got an IDE to SATA adapter,connected everything and fired up and I get the power to the drive as I can open the DVD drawer, but the machine first gets stuck at the HP splash screen on my HP Compaq dx2300 mini tower, offering me standard options to enter the BIOS setings. If I don't do anything, machine continues to boot into Windows 7 with no further problems because secondary booting device is hard drive right after CD which is primary (as set up in BIOS by HP factory), but you can't use that brand new Sony IDE DVD burner.
How to make the machine recognize it? I set the jumper on the IDE DVD burner to MASTER, but some people on internet say you should remove the jumper completely and let the machine sort it out. Also, in control panel under 'Device Manager' it says I have IDE ATA/ATAPI channels 0 and 1 working properly. To me, it seems also like I have an IDE 40-pin connector on the motherboard.
In BIOS however, all I see is 4 SATA ports although if I go into any of them, there is an option to auto-detect IDE hard drives. The only thing is that I don't need IDE hard drive detection, but IDE DVD-RW drive detection. Are there any differences between setting up IDE optical drives versus setting up IDE hard drives. Do I even have to be concerned about BIOS?
Thanks a lot guys and please ask me if you need anything else.
