Hi,everyone I have an Asus P5GZ-MX motherboard with only one(primary) blue ide connector.I have an Western Digital wd600 60 gb ide hard disk and an ide lg DVD writer.The wd hard disk has no jumper attached although there are jumper pins on it.I don't know where the jumper has gone.The DVD writer has its jumper set to master.When I connect the grey or black ide to hard disk,hard disk works well.But when I attach DVD writer to either black or grey connector, both devices are not detected in Bios.What should I do to get both devices work together ?I had bought this old hard disk as my motherboard does not boot my new sata hard disk wd500 caviar green, although it used to boot my old sata hard disk( now damaged). I will ask about that in another post.Should I buy a jumper and set hard disk to master and dvd drive to slave or selecting dvd drive alone as slave will do the trick? I still don't understand why black is master.If you connect hard disk to master(or black),How will you connect grey to DVD drive which is on top of hard disk in cabinet? Please help me getting this work.Thank you in advance.
