Ide-sata drive not working
swords24
132
i have plugged in a ide dvd drive to a ide-sata adapter and it wont detect the drive (but the drive still gets power), i have tried all the sata ports, but to no avail.
and yes i do know for a fact that the drive works
also its not showing up in the device manager
any suggestions?
870s-g46 mobo
hitatchi GCC-4482B
phenom ii X4 960T
8GB corasir ddr3 ram
haf-912 case
raedon hd 6850
rosewill green 650W
swords24
132
i dont think is is, would that be in the bios? cuz i dont even think i can find it there but ill check
Nope, edited my post, it is a set of pins on the back of the drive.
This is not your drive, but should be similar. the jumper needs to be under the MA or MASTER section. In some cases, just removing it will work as well
swords24
132
as soon as you said jumper i knew what you were talking about!
(ive had some bios problems where i had to play with the jumper for like an hour)
i think i got it, its the one labeled MA im assuming
testing now, brb
