Hi guys, I'll try and keep this brief as to not confuse things: My friend was having troubles with her computer, I offered to fix it, and straight away thought it'd need a new motherboard, I ordered one (an Asrock P4i65g) and even after countless hours and help from a couple of friends it just wasn't booting up.
Anyway, I decided to go back to the original motherboard and work with that. It boots into Windows just fine, but it hangs at regular intervals; when you first login, it sits and does nothing until you press ctrl, alt and delete, also if you try to open a window that references the CD drive it'll hang too, although everything other than that particular window works just fine.
I ran an IDE test and it came back as saying only the HDD was present, so after much messing around with jumpers etc I eventually swapped the IDE cables around (at the motherboard end) and now the CD-RW works just fine, but the HDD doesn't. Hmm.
I'm 99% certain it's a problem with the IDE socket, I've checked and there doesn't appear to be any bent pins so I can't really understand why it would suddenly just stop. Any advice would be very much appreciated, I've been working on this for a silly amount of hours now and would just love to reach a conclusion. If there's anything I can do other than have to buy and fit yet another motherboard that'd be fantastic!
Thanks
Thanks
