G
Guest
Guest
Archived from groups: rec.games.trading-cards.jyhad (More info?)
OK my brain has been ticking over lately with an idea for a DAI/ser
wall deck, based around Cybele. Use your two master phase actions to
put Auspex skill card/s on Cybele, play a few groovy masters that
people can try and burn or steal with an action (The Rack, Powerbases,
etc), and Anarch Revolts. You might want to turn Petaniqua anarch with
Garlic's Legacy also. Get a Rutor's Hand at superior, and then use
Cybele's actions to put Condemnation: Doomed on vampires you don't
like and then untap.
If someone tries to steal your Rack or Powerbase, block them and
Bloodstorm of Chorazin (action fails, take a point of damage and go
away). If someone rushes Cybele, block them and play Bloodstorm of
Chorazin. If your prey tries to become anarch, block them and play
Bloodstorm of Chorazin. If someone tries to bleed you, block them and
play Bloodstorm of Chorazin. If someone tries to vote down an AR, block
them and play Bloodstorm of Chorazin. Anyone who's Condemned also
makes their Methuselah burn a pool. Throw in a few Revelations of
Despairs also; only works againt your predator's actions, but your
predator will presumably be acting against you at some stage. Block,
play Revelations and then Bloodstorm. Two damage (basically
unpreventable), no combat, nice try goodbye.
A few times of doing this, and people should give up trying any actions
against you (if they know what's good for them). Cats Guidance helps
you untap and block actions (and can give intercept). It can also let
you avoid paying the Infernal penalty if you Cats after the last action
you have to block (a fair few wakes will be required also). Elizium:
Sforezco castle could also be handy here (depending on metagame).
If your prey's vampires are all in the bin before their pool runs out
(possible, depending on how many actions they try), bleed for three
with Cybele's built in.
I'm thinking the deck would run with 30 or so masters, 10 or so
actions and 60 reactions.
What do people think? Could this work?
Another alternative would be Petaniqua Advanced; she comes with Auspex
built in (which is awesome), but has no Serpentis or Animalism, and no
additional master phase action 🙁
