Ideal DPI settings for MSI GS65 8RE lappy
I Recommended set to 100% for best compatibility with apps and for things to be just the right size. If that doesnt see right keep it at default
It basically makes elements like font, task bar, icons, etc bigger or smaller. It's used to adjust elements on smaller or larger (or closer or further away) displays. Should not impact performance as it does not increase or decrease resolution.
