What is the ideal minimum idle temperature for a GPU?
Is it better to keep it near 45-50°C, or should I go down to 30(or as much as possible)?
I'm thinking that it's better if there is less deviation between idle and under load temperatures, but I might be wrong.
Also, which is better for the fans? Turning them on only when temperatures rise, or should they spin at least at minimum rpm at all times?
