Ok guys,I need some help in identifying if my ram module is with high density chips or not.
The ram module is Samsung 4GB M395T5160QZ4-CF7
Other markings are 2Rx8 PC2-6400U-666-12-E3
M is for memory module
3 is DIMM type
95 is x72 240pin Fully Buffered DIMM
T is DDR2 SDRAM (1.8V VDD)
51 is depth 512M
6 is 8 Banks & SSTL-1.8V
0 is bit organization x4
Q is component revision 17th Gen.
Z is FBGA (lead free)
4 is PCB revision 4th Rev.
On ebay it is advertised as high density ram and only compatible with AMD processors.
It has 16 chips on one side and 16 on the other side.
If it is with high desity chips ,then there would be a lot less chips on the module as high density chips need less space on the module.
Some sites labeled this as server ram.
I am using it with Amd processor
Will this work with Intel processors.
Any help is appreciated.
3 is DIMM type
51 is depth 512M
